Creo 2.0 Modelcheck.
i need to how to enable Initialization setting > Edit Config_init.mc ---- This Error Shows "File Not Accessible" how to edit this settings
Deepak,
Open Config_init.mc externally and check if MC_AUTHORIZATION_FILE is set as yes. If it is yes, there will be file holding the list of authorized members.
You need to run Creo as administrator to access the Model check files from Creo.
