HI All,
I am trying to install windchill 11 , but i have window 10 . I am unable to install windchill on that OS. I checked software matrix , No window 10 mention there , only window 7 & window 8 mentioned there . Please let me know , is there any way for install any windchill on window10.@
Apparently Windows 10 is not enlisted in the support matrix for installation of WC 11.
However a couple of workarounds/ fixes are available in the Knowledge base, like for running the PSI, one must follow :
Run the setup.exe from Disk1\InstData\Windows\VM folder through command prompt as below:
C:\Users>"<Path of staging area>\PSI\Disk1\InstData\Windows\VM\setup.exe" -i GUI
Regards
