license error
SamuelAlexander
license error
hi,
i am working on a system which is a server for creo 3.0. we total of 3 licenses. My colleagues who are working on creo 3.0 on other system are frequently facing license lost error.
Each time they loose their license i have to manually restart Lm admin utility in my system. I have to do it in every 2 hours approx. Is there remedy for this error.
Thanks in advance
Regards
3 REPLIES 3
You need to file a support case. This is often a time-out issue on the server. This should be easy for PTC customer support.
Samuel,
your problem is site specific. Probably your network does not enable Creo workstations to communicate properly.
Martin Hanak
Martin Hanák
