I am using Creo Parametric Release 6.0 and Datecode6.0.4.0
Microsoft .net error
Unable to install Creo 6.0.4.0 Due to Microsoft .net (4.7.2) error
Windows 7 Service pack Install
as mentioned in https://www.ptc.com/en/support/article/cs318438 you have to:
remove the following line from the pma.xml file located in Creo CD image\pim\xml directory:
<PREREQUISITE required="Y">dotnet4.xml</PREREQUISITE>
