newly shown dim will not un-hilite
davehaigh
Ok what am I doing wrong? I'm in Creo 2.0-m070.
I just added a round to a part and showed the dim on the drawing and moved it where I wanted it.
Now no matter what I do, I can't get it to un-hilite. The only recourse is to save, erase from memory and open it again.
I've tried regenerate active model, update sheets, & update draft.
[cid:image001.png@01CEF5B3.92867700]
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
And the answer is: From Ronald Grabau,
The system thinks you are still in creation mode. Middle mouse pick on the background, and then repaint to clear it up.
David Haigh
