nmake with directories containing spaces
Newbie
Hello Programming Gurus,
I am trying to use the make files supplied by PTC with nmake on Windows.
Because there are about 20 make files, I would prefer to edit the make
files rather than create the build instructions in the IDE.
The default installation directory for Pro/E now is in "c:\Program Files".
I would like to say:
PROTOOL_SRC = c:\Program Files\proewf
but the space in "Program Files" ends the macro. Neither using quotes
(") or a caret (^) works. Any ideas?
TIA,
Bob
Robert A. Monat
Jerand Technical Services, Inc.
http://www.jerand.com
Phone: 317-875-6087 FAX: 317-875-6612 Tollfree(US)888-4JERAND
Re: nmake with directories containing spaces
> Windows.
> make
> Files".
> TIA,
> Bob
Bob,
Haven't tried it yet, but since you must "escape" backslashes w/
another backslash (\\) then try escaping the spaces as well:
C:\\Program\ Files\\proewf
Michael L. Fussy
Timeous Systems
(407) 291-9270 Tel
(407) 291-9269 Fax
Bob,
The workaround I used was to define the windows program directory using its
'DOS-name' (Progra~1 on my system - not sure if this is universal). My
makefiles contain a block that resembles:
WINPROG_DIR = C:/Progra~1
#PROVER = 2000i2
#PROVER = 2001
PROVER = Wildfire
PROTOOL_SRC = $(WINPROG_DIR)/proe$(PROVER)/protoolkit
PROTOOL_SYS = $(PROTOOL_SRC)/$(PRO_MACHINE_TYPE)
PRODEV_SRC = $(WINPROG_DIR/proe$(PROVER)/protoolkit
PRODEV_SYS = $(PRODEV_SRC)/$(PRO_MACHINE_TYPE)
This should solve the problem you have.
Best,
Michael
