parameter table
SkyKing
parameter table
I updated a parameter table to what I want to see for a model and saved it to use for future models  (rp_config.xml). I also put “parameter_dialog_setup_file” to “config.pro”. When I go to create a new model, the new parameter table is not there automatically. I also did load config. to the rp_config.xml, and that did nothing.
Mahesh_Sharma
22-Sapphire I
(To:SkyKing)
Ok, now it is clear.
rp_config.xml with config  parameter_dialog_setup_file is to setup customize parameter table change in columns and width will record in file.
To have defined parameters when creating new parts you can update the template part.
10 REPLIES 10
Mahesh_Sharma
22-Sapphire I
(To:SkyKing)
Can you upload rp_config.xml in post?
Should show below.
Mahesh_Sharma
22-Sapphire I
(To:SkyKing)
I think you would like to control the width of column in parameters. If this is correct, I checked your file however that contains less width.
You can open the file in text pad and define the column and that should work.
Are you saying for me to increase those numbers in "rp_config.xml" and it should work?
dschenken
(To:SkyKing)
Do you want to create the parameters and set the values using the .xml file?
Yes, I want to create the parameters and set the values to be use in new models. I want to see like below when I create a new model. Is that possible?
Mahesh_Sharma
22-Sapphire I
(To:SkyKing)
If I could I would mark Mahesh's answer Correct.
BenLoosli
(To:dschenken)
Only the OP can mark an answer as correct
It would be nice if the product champions can have this ability, too.
Also you might want to create a separate folder for those template files and apply them to “config.pro”, so you do not lose your template when you go to upgrade.
