pfcExceptions::XToolkitBadInputs    at pfcls.IpfcBaseSession.GetConfigOption(String _Name)
Srinivas_Kayala
I am using Creo Parametric Release 4.0 and DatecodeM140
We are getting an exception "pfcExceptions::XToolkitBadInputs    at pfcls.IpfcBaseSession.GetConfigOption(String _Name)
   at proetopdf.proetopdf.Main(String[] cmdArgs)" when used with a solid regenerate API.
As per the PTC Support knowledge base understand that this issue is with the Creo 7.0 where the API is a deprecated.
Presently we are getting this issue in Creo 4.0 M 140 and need your help in understanding the root cause and the resolutions already if any. We have an inconsistent exception now which is observed for few sample files only.
Article - "Getting exception "pfcExceptions::XToolkitBadInputs" when calling IpfcBaseSession.GetConfigOption() by Creo Parametric VB API": https://www.ptc.com/en/support/article/CS328846
