It appears to invoke this command from the GUI.
Clear all apearances
Thank you for the reply first..
And can I ask you 1 more thing.
I want to know what is
mapkey ac @MAPKEY_LABELauto color;\
mapkey(continued) ~ Select `main_dlg_cur` `View:ProCmdViewGallery`;\
mapkey(continued) ~ Close `main_dlg_cur` `View:ProCmdViewGallery`;\
mapkey(continued) ~ Command `ProCmdViewAppearanceEditor`;\
I really appreciate your reply
And can I ask you 1 more thing.I want to know what is
it would be nice from you to run mapkey and then find UI command related to it. It's not difficult and at least you'll learn something yourself.
