Hi, parameter pro_mp_mass is not updated even when I compute mass properties.
This on is updated when I change some dimensions but not the parameter.
The only solution I've found it to go in prepare model / mass pro / change (geom & param) and the compute.
I can't understand why it is not automatically computed as it was in the pass.
mass_property_calculate is already set to automatic
I've certainly change something but don't know what (in parts, in config.pro...)
Thanks for any advice
May be check your config.pro file "mass_property_calculate Automatic "
I tried its working fine.
Mani
Mani
