[proesys] - Command
Highlighted
[proesys] - Command
By adding the "-v" modifier to the ptcstatus.bat file, you will also get
information about what version of software you are using (WF 3.0 = version
27.0), you get the expiration date of the license, and you get your SCN
number. These extra pieces of information may be of some assistance.
Bob
Highlighted
[proesys] - Command
The only difference it gives me is the version of Flexlm, when I run it
from my workstation.
If I run the command from the license server, then the -v does what you
describe below.
