Anyone know of a good way to add a company proprietary statement to a start part? I suppose an annotation note would work but wondering about other ways.
What is the intended end use?
Are you creating drawings and want the note on them?
Are you doing MBD and need the note in the file?
Are the files being exported from CREO by STEP or IGES? These can have a proprietary note placed in the export file, I believe.
Not trying to conform to anything legal but just want something in models (not drawings) that is fairly obvious. Realize it could be deleted.
Annotation note is probably the easiest.
I think, security marking can be one of the options.. details are at http://support.ptc.com/help/archive/creo40/creo_pma/usascii/index.html#page/model-based_definition/about_security_marking.html
Yes security marking looks like the ticket. The Security Marking button is greyed out though. The note is unattached and flat to screen as the instruction notes. Not sure how to light it up.
All files. It will be added to our start part template. I opened a case with PTC and they said they couldn't get the Security Marking button to light up either and passed it on to development for investigation.
Similar to Ben's questions, is this something you want hidden to prove someone took your file in the future, or do you want it plainly obvious to everyone who uses it, but potentially easy to delete?
