ptcstatus path
jtruitt
7-Bedrock
ptcstatus path
I'm trying to run this batch file but it cannot find the path specified. I'm not entirely sure how to correctly reroute it to the right locations. Can anyone help?
StephenW
(To:jtruitt)
I use the dos window cmd to run. I change directories to the folder it is in.
In my case, it's under C:\Program Files\PTC\Creo 3.0\M070\Parametric\bin
Notice the creo 3.0 and M070. Youll need to get your path right and then right click on the 'COMMAND PROMPT HERE'
type ptcstatus there
StephenW
(To:jtruitt)
Command prompt still returns with "The system cannot find the path specified."
Edit: I just tried this method on a different Creo install that is located on our license server and it ran through fine so this did the trick. Thank you!
TomU
(To:jtruitt)
You should be able to just browse to the bin folder and double click on it.  The script includes a pause so you can read it before it closes.
