Hello Lyle,
The times I have seen this message it related to memory issues. For instance,loading the results from your analysis may require more memory than can be allocated. Iused to have these issues when I was working onWindows 32 bit.
Somepossible solutions are:
1) Turn off continuous tone(ifchecked).
2) Turn off animation or reduce the numberof frames.
3)Restart ProE and try viewing the results again. Sometimes due to memory leaks ProE will retain some memory from prior actions.This additional memory allocation could make itssuch the entire results cannot be loaded into the allowable memory space remaining.
4) Review the resultson a 64 bit workstation.
5) If on Win XP 32 bit you can enable the 3GB switch bootup option. Just google around for this.
Hope these help,
Steve
Stephen Seymour, PE
Seymour Engineering & Consulting Group
In Reply to Lyle Beidler:
WF3, M160
I've successfully run a Mechanica Structural analysis, but when I configure
a results window & hit "ok & show" I get the following error message:
"none of the selected result windows can be shown"
Can anyone tell me why I might be getting this error?
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<mailto:-> -
<http://www.mgsincorporated.com> http://www.mgsincorporated.com
