renaming parts outside of a PDM system
dgschaefer
Set the config option 'let_proe_rename_pdm_objects' to yes.
Doug Schaefer
LinkedIn
Tony,
FYI, if the object is already in commonspace and you use this config option, you will simply create a new object.
If it's not in commonspace, then no worries.
Thanx all. Never knew about this option, cause I never had a PDM
system.
Thanx
T
