renaming .proi
ptc-169947
renaming .proi
Hi all,
I asked once a while ago and got many responses but forget to write it down.
I have a .proi that was renamed to old.proi which I need to rename back to .proi
Can't do it in explore and remembered that it's possible in a command window. Anyone know the syntax?
Stefan
1 REPLY 1
lwh
(To:ptc-169947)
It's not possible in the Windows explorer, as this needs a name in front of the dot.
Use the command shell (cmd.exe) and rename the directory:
RENAME C:\data\proework\old.proi .proi
