Anyone is having issue running Solidworks 2017 and Creo 5.01 on the same laptop?
Don't forget to mark your answer as correct for those who may search and find this thread.
Are you possibly running Windchill 11.1? There is a known issue where the embedded web browser doesn't work correctly when Creo 5 and the workgroup manager are both installed. See CS289364.
I'm also having a different issue with Windchill 11.0 M030 (CPS11) where the workgroup manager does not start correctly with Solidworks 2018 (SP4). This issue has not been resolved yet...
Thank you for the update, I found the issue to becoming from windows update version 1803. It's messing up my license with Flexnet
Actually, unmark mine and mark your. 🙂
