Hi Doug,
I simple method to remove the splash screen and uTools startup is to remove the following entries from the protk.dat (located at <proe_loadpoint>\text):
name uTools
startup java
java_app_class uTools
java_app_start start
java_app_stop stop
allow_stop true
delay_start false
java_app_classpath D:\ptc\proe31\text\java\uTools.jar
REVISION 0.0
end
Note: the entry REVISION 0.0 is used by PTC to activate faster startup (from WF5 on)
Best Regards,
Martein Schuttert
Team Leader Services Product Development
USG Innotiv
