search_path does not work
ptc-2486294
1-Newbie
I'm trying to use search_path in config.pro file but it doesn’t work. I don’t know what is wrong because when i add search_path to my config.pro flie it is working until I switch off proe. Next time I start proe i have to go to tools options and open config.pro file to make it work(otherwise i won't be able to retrieve files from other folders). Config.pro should load everything automaticly but for some reason it ignores my search_paths. My config.pro file is inside ...proe...text folder. can somebody tell me what to do to fix this problem?
2 REPLIES 2
Artur, Does you search path file contain any spaces in the path? ProE does not recognize any spaces in the path name. For example these are correct paths: \\Mspserver\NPD\PROE_FILES\PROE_COMPONENTS\SCREWS \\Mspserver\NPD\PROE_FILES\PROE_COMPONENTS\CONNECTORS \\Mspserver\NPD\PROE_FILES\PROE_COMPONENTS\EXTRUSIONS \\Mspserver\NPD\PROE_FILES\PROE_COMPONENTS\O_RINGS \\Mspserver\NPD\PROE_FILES\PROE_COMPONENTS\INSULATORS If you are using, for example "My Documents" in the path, ProE may not recognize it. Hope this helps
Thanks very much. It helped indeed
