settings in drawing mode
BN-disabled
Is it anyone that knows how to change the default setting of the offset and increrment value in the cleanup dimention mode??
7 REPLIES 7
Hi
Did you ever get an answer to this question as I'm looking for the same information.
Nick
default_clean_dim_offset
default_clean_dim_increment
Reinhard
Thank you, I'm still working in Wildfire 4, so I guess these changes came in after as I can't seem to get them to work, just have to wait till I can move onto Creo !
regards
Nick
Hello, Mr. REINHARD NUECKEL where do I find this setting in which the 2d confi.pro or WF4 full already googled it and not found at all, and the possibility and put it in my config.pro?
grateful ........
Hi
I tried to add these setting to my .dtl file in drawing mode (properties, drawing options) on WF4 but they don't appear, I think you require an newer version of proE.
nick
its a drawing (.dtl) option unfortunately for WF5 or later.
Reinhard
yes I'm trying to creo 2.0 also no longer TA accepting it.
