Community Tip - If community subscription notifications are filling up your inbox you can set up a daily digest and get all your notifications in a single email.
X
[solutions] - Feel like I've been living under a rock - Network installation of Creo 2.0 not su
On 06/27/14 14:05, Villanueva, Antonio UTAS wrote: > > Ok, just moved to Creo 2.0 and we've tried experimenting with installing Creo as a mapped network > application. >
That still works good with the exception that Creo 2.0 will install (locally) Creo Platform and Creo Thumbnail Viewer (as you have already discovered).
> This is preferred when users lack administrative rights and you have limited IT staff. Great. > Installs ok. Starts up, seems to work fine. There are number of little issues with the extra apps > it tries to install on startup but those are minor. Ok, let's connect to PDMLink and start > working. Wait where did server registry go??? > > Short summary -- if you do not install the Creo Agent (Creo Platform), you cannot save the server > registry. Lost when you shut down. > > https://www.ptc.com/appserver/cs/view/spr.jsp?n=2157073 > > CONFIDENTIALITY WARNING: This message may contain proprietary and/or privileged information of UTC > Aerospace Systems and its affiliated companies. If you are not the intended recipient please 1) do > not disclose, copy, distribute or use this message or its contents, 2) advise the sender by return > e-mail, and 3) delete all copies (including all attachments) from your computer. Your cooperation > is greatly appreciated. > > > ----------
