[solutions] - Windows 7, Right Click
ocorten-2
Hi Eric,
Check out my OCUS Win7 Creo Purge utility.
You could easily tweak it to run your own script.
Kind regards,
Olaf Corten
Olaf Corten
CAD/PLM Manager
Besi Netherlands B.V.
Ratio 6, Duiven
Phone: +31 26 3196215
Mobile: +31 644548554
www.besi.com
To: "-" <->, "-" <->, "-" <->
Date: 25-04-2013 01:30
Subject: [solutions] - Windows 7, Right Click
Gurus,
I’ve got a .bat file which runs the purge command and deletes all the garbage files which I want to add as a right click option. I’m new to Windows7 so when I searched on this topic it is clear that the XP method to add right click to folder is gone. Can anyone walk me through the process of adding my file D:\working\CLEANPRO-ALL.BAT as a right click in Windows7. I’m guessing this has to be a regedit at this point but I welcome alternatives.
I’m also curious if there are new methods besides batch files to do this.
I found a couple of hits on this top but nothing new so I thought I would check to see if there is a new fix, apologies for the off topic and multiple posting.
Eric
Site Links: View post online View mailing list online Send new post via email Unsubscribe from this mailing list Manage your subscription
Use of this email content is governed by the terms of service at:
0 REPLIES 0
