unwanted thin surface
JustinSauber
I am having an issue where a thin surface appears in a hole after creating a weld lip using a revolve.
The hole in the center of the part is a thru hole. Anyone have any ideas what causes this?
Wildfire 4.0 M220
NVIDIA quadro K2000M and Intel HD Graphics 4000
(4) Intel Core i7-3720QM CPU @ 2.60GHz
4 REPLIES 4
I've seen that sort of thing before.
Check your sketch for small edges, also try turning your accuracy down as small as it will go.
Regards
Sarah Ford
CAD Designer/Admin
Westwind Air Bearings
Tel. 01202 627236
StephenW
(To:JustinSauber)
I get that same phenomenon occasionally. It's not really there on mine. It doesn't show up in drawings but at certain shaded views, it looks just like what you have. I haven't solved it yet but it doesn't seem to cause other issues except visualization.
I made the accuracy .0001 and that fixed it. Thank you.
Justin
.0001 works 9 out of 10 times.
