warning messages when saving
gbon
Hi alls,
I can't avoid warning messages when I save models.
'' model xxxx is not regenerated''
'' mass properties are not calculated''
Config option mass_properties_calculate is set to ''automatic''.
But, I get those messages at each saving and:
- I have to click on ok
- It seems to mean that something is not correctly calculated and
may be wrong on drawings.
So, how to avoid this?
Any advice?
GB
5 REPLIES 5
ptc-1932745
2-Explorer
(To:gbon)
Is this in CREO 1/2 ? Because I get the same messages, at least in CREO1, but not CEP/WF5
Christopher F. Gosnell
FPD Company
124 Hidden Valley Road
McMurray, PA 15317
dgschaefer
(To:gbon)
It's a bug, but I'm not sure PTC sees it as such. A double regen avoids the message but sort of defeats the purpose of automatic calculation of mass props.
LinkedIn
TrainStopper
(To:gbon)
It's a bug and I wish they would fix it, it didn't used to be this way.
Can't really call it automatic since it isn't anymore.
For simple models a second regen is quick and maybe they could look the other way.
For more interesting models, bigger nested assemblies with family tables, mechanisms, and such, running a double regen takes several minutes per instance.
I spent several hours today in mass property regen hell to get that nice green dot.
Fix it!
Walt Weiss
I got so sick of the "not regenerated" msg that I created a mapkey that would regen and then save. I still get the message in the middle of the mk execution and have to run it a second time.
Sent from my mobile device
On Jan 15, 2014, at 2:09 PM, "Doug Schaefer" <<<a style="COLOR:" blue;=" text-decoration:=" underline&quot;=" target="_BLANK" href="mailto:">>">mailto:>> wrote:
It’s a bug, but I’m not sure PTC sees it as such.  A double regen avoids the message but sort of defeats the purpose of automatic calculation of mass props.
rmast
(To:gbon)
Usethis option to avoid the pop up message.
regen_solid_before_save NO
