where is uwgm.log located
ebeattie
Where is uwgm.log located? I have not been able to locate it.
3 REPLIES 3
I believe as a default set up, you should find it in either your working directory as defined in the "start in" location of your app icon
or
in windows default location
c:\Users\<username>\AppData
the AppData folder may be hidden
I have always set the "start in" location but have never seen this file.  Is it removed when you exit Pro/E?
It looks to be part of the ecad package/programming
Never seen this file? - can't say I have either.  did a windows search for "uwgm" and found stuff in my <loadpoint>\common files\text\usascii folder.
Is it removed?  Can't say.  You may have a purge program that runs and kills all *.log files. I don't think I ever generated one so I can't find an example locally.
Probably do some googling to find out more.
