Changing the order of items using CLI or Excel Integration tool
jjohnson-10-11-4
3-Newcomer
Hi All, We recently imported a ton of data, and now it looks like we need to import some headings as well, but we'd rather not import them and then reorder them if theres a simpler solution. Any ideas? You can map the 'Section' field and export it, but you can't modify it and sync it... (tried that)
Thanks!
Jeff,
This will probably be quicker if you contact support and open a case so that we can work with you on it. A support engineer will probably need to take a look at what you've done and what exactly you need, which is easier with more direct contact.
