How to set Global Policy for Change Packages?
Can we set the Change Package Reviewers to multiple users and anyone can approve/accept the change package (No need to accepted by all the members listed .) we don’t want group.
Requirement is the out list of reviewers any one can accept the change package
Hi overcautious anonymous community member A A,
well IMHO (based on personal experience and reading the manual
) the only way to achieve the behavior you want (only one reviewer out of a group of reviewers need to accept the CP) is using groups.
The property setup is quite straight forward:
Every "principal" (being a user or group) that is listed in the "Change Package Reviewers" property must accept the CP.
This means:
and of course you can mix this
The "append" checkbox indicates that in a hierarchical setup the reviewer property can be inherited from the upper level and is only extended by the current entries.
HTH Matthias
This means:
HTH Matthias
