I'm currently using Integrity 10.6. I quite often use the Edit-In-Word feature for the entire document, However when publishing the changes made, it always gets stuck at the items which are "shared".
Is there a possibility for the Editor to skip the publishing of an item whenever the reference mode is shared?
many thanks in advance for your help
best regards
Hello Shih-Fu,
please refer to one one of the other posts about this topic:
Hope this helps
Volker
