It had happened when I imported a reqiurement document (Integrity v10.6).
Thanks!
Hi Roy,
can you check whats the correct name for your Requirement Document type inside your Integrity Admin? Perhaps without Prefix?
Then, check the file gateway-tool-config.xml located in your client (or gateway server directory) if this name (with prefix ALM_) is there. Then, adapt the names to match to what you have in your Integrity Admin.
Does this help?
Volker
Hi Roy,
Does this help?
Volker
Hello, Volker
Thanks! I checked my Requirement Document type inside your Integrity Admin as following:
Is it without Prefix? How do I modify it?
and I searched "ALM_Requirement" in gateway-tool-configuration.xml file, but no found anything.
Thanks!
Roy,
Ok, hm, can you please tell me which Import configuration you choose?
And, is it right that you import a word document (docx)?
Volker
Hi, Volker
OK, The document (docx) is right, and the configuration as following:
Thanks!
Hi Roy,
Your configuration is indeed without the ALM_ prefix. Your gateway-tool-configuration.xml seems to be correct too.
Next step is to look at the mapping and maybe even at the properties file.
Another confusing thing is that there's a local and a server version of the gateway configuration and mapping files. As admin, I made sure that no one has the local files anymore. I renamed the server files (in the file itself, the file name doesn't really matter) too so that I'm definitely working with the right config.
Another remark. We only import excel files, and I didn't manage to import xlsx. We import with the old xls format. Although your configuration mentions docx only, I'm not sure it actually works. But given the error message, I wouldn't bother for now.
Check the mapping files first. I bet you find your reference to ALM_Requirement there.
Adriaan
Hello Roy,
Most of the information Adriaan supplied is available to entitled organizations via CS172951: Gateway Knowledge Hub. This information is also available in the Gateway User Guide, which should be on your server's homepage under Documentation.
Kael
Hello roy zheng,
Here is the process in more detail than is provided in CS132252:
I hope that helps.
Kael
