Getting List of active projects in xml
mkhan-2
Hello
I am trying to get all the active project lists from MKS into XML. I tried using "im projects" but I don't know (nor I find )how to filter only active projects and then put it in XML. Thanks for your help in advance.
3 REPLIES 3
mkhan-2
(To:mkhan-2)
im projects --fields=id,name,isActive seems to be giving me the results. I want to now just get the results where "isActive" is yes.  Any help would be appreciated.
Hello Muhammad Khan‌,
Take a look at CS166082, which explains how to use the mksAPIviewer.exe file located in the client's bin directory.
Kind Regards,
Kael
Kind Regards,
Kael Lizak
Senior Technical Support Engineer
PTC Integrity Lifecycle Manager
What about a simple XML report, that scanns the Backing Items and export them as XML?  (assuming the backing item has been disabled when the project is also disabled.)
