Hello All,
We have 2 system requirement secification documents, say for example Document A and its branch document Document A1.
Document A1 has additional changes and new requiremetns added into it and we want to compare these changes and other differences from the original document A.
How can i compare the differences between Document A & A1.
I cannot use the 'view differences' option as they are 2 different documents
I cannot use compare unrelated documents option because these are related documents by branching.
Looking forward to your feedbacks.
Note sure which version of the Product you are using, but a more later version does give you this option. Hope this helps.
