How to auto sync sandbox.
skrisnamoorthy
Is there is any way to auto sync the sandbox from a specific location?
Shankar
I suggest to use a windows script on a scheduled base, using the CLI command "si resync".
With the parameters of that command you should be able to sync the data you need.
Greetings,
Klaus
2 REPLIES 2
Hello Shankar,
I'm trying to imagine what you mean by auto-sync. I'm guessing your use case involves the latest members of the mainline or a devpath updating automatically triggering a sandbox to do a refresh. Is that what you are trying to do?
This could probably be done with a trigger script running off of configuration management events, but would likely involve writing your own custom trigger script to do so, or getting a Global Services engagement to write such a trigger script for you.
Kael
Kind Regards,
Kael Lizak
Senior Technical Support Engineer
PTC Integrity Lifecycle Manager
Greetings,
Klaus
