The PTC Community will be on read only status starting March 23rd in preparation for moving our platform to a new provider. Read more here
Currently I've a requriement, whenever a defect or item is created I need to open one url via trigger. Let me know what is the code to open an URL via trigger?
Thanks & Regards,
shankar
Do you want to open up the Integrity web client to a specific item/object or do you want to open a browser to an external website?
I want to open a external website(JIRA URL)
Anyone know how to open a URL from a remote machine?
Shankar
Is it a fixed URL or a dynamic URL, depending on infos from out of the item itself?
Greetings,
Klaus
Hi Shankar,
I'm looking for a similar solution in a different use-case.
I would like to trigger my build server (Jenkins) when checkpoint is created in Integrity (and the project meed some special conditions).
So basically I need a way to KICK-OFF the "run build URL" on my Jenkins from inside my Integrity java script source trigger.
Of course the trigger must be non blocking.
Did you find a solution so far?
Regards Matthias
Hi Matthias,
I can provide a solution for your use case (we have the same use case):
var eb = bsf.lookupBean("siEnvironmentBean");
var pb = eb.createProcessBuilderBean();
pb.setCommand("wget -q --spider --no-check-certificate --http-user=xxx --http-password=yyy https://zzz);
pb.start();
Regards, Ingo
Thanx Ingo, you just saved my day ![]()
Shankar,
What was it about this answer that did not resolve your request? Maybe we can tailor it to meet your needs?
Kael
Here's an alternative for those users on Windows Servers that do/can not want to use "wget".
It's the same command in PowerShell and works just great for us:
pb.setCommand("powershell.exe -command \"$client = new-object System.Net.WebClient;$client.Credentials = New-Object System.Net.Networkcredential('xxx','yyy');$client.DownloadFile('"https://zzz/"' , 'c:\\temp\down.html' ); \" ");
pb.start();
HTH Matthias
