How to set a "state transition management" in RVS?
AN_10548594
Good day,
How to construct a trigger rule for following usecase: Requirement State CHANGES from Published to InWork?
I was able to construct a rule for a State[New] = InWork case. But for me Published->InWork and OtherState->InWork are not the same. My trigger should be invoked only for "Published->InWork" case and not for cases like "OtherState->InWork". How to achive this kind of "state transition management"?
Hi @AN_10548594,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
