I have a problem with a DOORS (9.6) module that I am trying to update via IRC (3.4). I have a module named SPEC_A that was imported in DOORS baseline 1.0 using a ReqIF file with IRC. This module was later renamed SPEC_B, evolved, and moved to DOORS baseline 2.0. Since baseline 1 was a DRAFT version, I deleted the initially imported module,
thinking that since it has changed its name, IRC would consider it as a new module and therefore perform an “insert.” However, when I tried importing the new module with the changed name (SPEC_B) via IRC, IRC tells me that SPEC_A does not exist…
I try to restor a SPEC_A to import a .dma in the tagert path in order to have a correct target on the path of IRC but I think that the importation of the dma haven't the same id hat the original SPEC_A module and IRC and IRC no longer recognizes the module SPEC_A...
Do you have any solutions?
I thought that IRC would understand that changing the module’s name would be considered as a new module (and therefore treat it as an insert), but that is not the case...
Hi @RL_13916218
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
