Ignore Blank mapping - Windchill requirements connector 4.2
VR_10696444
Hello All,
I am currently using the following :
PTC RV&S v13.2 and Windchill requirements connector 4.2
Scenerio:  Until all the requirements in RV&S are set to in analysis state, the feasibility status field will not be editable. Since a requirement document can have varying levels of requirement states, i have issue particularly for the requirements in the "draft" state.
Issue: When i make an reqIF exchange with partner who will be updating the feasibility comments and feasibility states and when the requriements are sent back in a draft state, the requirements connector tries to update the fields in RV&S but since there is an editability rule, the import ends up in a error.
Is there a way for the requirements connector to ignore the mapping of the draft state requirements ?
Hi VR_10696444
Thank you for your question.
I encourage you to bring more details and context to your initial inquiry. This will make it easier for you to receive meaningful help from other Community members.
Andra
