Integrity ALM Installation - Existing Environment
mattia
2-Explorer
Currently our MKS installation activates only Requirements and Tasks as work items.
Our MKS server manages the repositories, Build for miscellaneous big projects and a ~big number of users (arround 2000).
My Question:
It is possible to install the ALM of MKS without disturbing the current environment?
What is the risk: to perturb the current users/projects/workflow?
This Question is very important for me:
What about the estimated Time to install and use the first ALM with default ALM template?
Thanks in advance
Miled Attia
DanR.
(To:jgorsline)
I will second that. We currently have 2 Integrity Servers. One for production and one for test. The ALM does make a good deal of changes. As Jeremy stated, I would recommend you install it on a seperate Integrity server. We are not presently using it, but it provides good examples of how it could be used.
jgorsline
(To:mattia)
No, you cannot install the ALM solution onto an existing environment without disturbing it. The ALM installation makes a great number of big changes and cannot be uninstalled.
As per your other post, I would recommend a test environment to work with ALM.
As for time, I have set up test servers and installed ALM on top of them from scratch (VM->OS->Integrity->ALM) in less than an hour start to finish, so it is not a difficult process.
DanR.
(To:jgorsline)
I would also add that you should make sure the ALM solution is actually the one you intend to work with, since most current generation solutions cannot co-exist together.
We recommend that you contact PTC Integrity Support or PTC Integrity Services to discuss your solution requirements before installing any given solution.
Kind Regards,
Kael Lizak
