Integrity - Field of Type "Phase" relationship
traker99
Hello everybody,
i have question regarding the field type "phase".We use a (custom) phase field to organize one of our workflows (Workflows and Documents->Types->"NameOfType"->Attributes->Phase Field).
For the future we like to deactivate the phase field from the corresponding workflow. Unfortunaly this field is a legency holdover of better times 🙂 and we do not have clear information about it.
At the moment we do not know if there is any relationship to aspects of the system like triggers or other important parts.
Is there a way to find out any related relationship regarding the usage of this phase field in the system? We need to be sure that there are no side after deactivation (not removal).
Currently we are using Integrity 10.8.
Thanks for any answer which may provide some clearification
awalsh
(To:traker99)
You should be able to get the references using the command
im fields --fields=references "Phase Field"
Here's an example output:
Object Type Name Creator
Item Presentation Template workitem
Admin Field Total Remaining Effort Administrator (admin)
Item Presentation Template testplan
Admin Field Pending Defect Count Administrator (admin)
Admin Field Open Change Order Count for Project Administrator (admin)
Admin Field Open Test Objective Count Administrator (admin)
Admin Field Pending Test Objective Count Administrator (admin)
Admin Field Pending Change Order Count Administrator (admin)
Admin Field Closed Test Objective Count Administrator (admin)
Admin Field Closed Change Order Count for Project Administrator (admin)
ViewSet Requirements Analyst
Admin Field Blocked By Administrator (admin)
Admin Field Valid Change Order Administrator (admin)
Admin Field Open Test Session Count Administrator (admin)
Admin Field Closed Test Session Count Administrator (admin)
Admin Field Pending Test Session Count Administrator (admin)
Admin Type Work Item Administrator (admin)
Admin Type Change Order Administrator (admin)
Admin Field Valid Test Step Change Order Administrator (admin)
Admin Type Test Session Administrator (admin)
Admin Field Closed Defect Count Administrator (admin)
Admin Type Test Objective Administrator (admin)
Admin Field Open Defect Count Administrator (admin)
Admin Field Blocked Administrator (admin)
Admin Type Defect Administrator (admin)
Admin Type Test Plan Administrator (admin)
Item Presentation Template testobjective
Item Presentation Template changeorder
Item Presentation Template defect
Admin Field Blocking Administrator (admin)
Item Presentation Template testsession
Admin Query Active Change Orders Administrator (admin)
Admin Query My Current Work Items Administrator (admin)
Admin Query Active Input Change Orders Administrator (admin)
Admin Query Active Requirement Change Orders Administrator (admin)
Admin Query Active Specification Change Orders Administrator (admin)
Admin Query Pending Defects Administrator (admin)
Admin Query Active Test Change Orders Administrator (admin)
Admin Query My Active Change Orders Administrator (admin)
Admin Query My Active Tasks Administrator (admin)
Query open defects developer
Admin Query Pending Test Sessions Administrator (admin)
Admin Query Open Development Tasks Administrator (admin)
Admin Query Closed Test Sessions Administrator (admin)
Admin Query Pending Change Orders Administrator (admin)
Admin Query Active Test Objectives Administrator (admin)
Admin Query Closed Change Orders Administrator (admin)
Admin Query Open Defects Administrator (admin)
Admin Query Closed Defects Administrator (admin)
Query test1 Administrator (admin)
Chart Defects by Phase developer
4 REPLIES 4
awalsh
(To:traker99)
traker99
(To:awalsh)
Thank you awalsh for the answer!
As i see its the same informationen as provided in the corresponding Client view "Reference" of the selected item. Is this the only posibility to check any references? How about triggers (besides searching in them)?
thanks again!
awalsh
(To:traker99)
Yes, you are right it's the same information.
It is the only way to check references.
For triggers, it will show if the field is used in a rule, but not if it's referenced in a parameter or in the script.
traker99
(To:awalsh)
thanks again for your answer!
