The message you are trying to access is permanently deleted.
I am getting this error since I have restored an Oracle backup.
The user/password are correct.
I have changed it in the Oracle DB several times with simple password to avoid errors. I can connect through sqlplus and sqldeveloper all the times.
Ok, I can be wrong even copy paste user and pass from a txt that works with sqlplus, but the next test is what made me atonished:
Any ideas??
Thanks in advance
Have you filed a support ticket with PTC TS?
Kartik
First of all, thank you for your answer.
Yes, of course, I opened a Case with PTC.
But the answer is "This version of product has been in so-called Sustained Support mode for more than two years. In this mode you have the following options to get help on your product version:
So we are paying for the support but we dont have a solution. This tool is used in a big project and cannot be updated every year.
Best Regards
With the utmost respect, I would like to point out that IRC 3.4 was released in April 2019. So, the upgrade has been due since 2021 at a minimum! Every release gets a standard 2 year support time frame.
Can you please confirm the current state - Is all your collaboration blocked, or are these problems on a test & trial version, and your production environment is secure and remains operational?
Please share your PTC Ticket ID details.
Kartik
Hi
I have been working with IRC since 2010, but I dont choose which version I have to use, is a responsability of the consortium. Even some partners are using previous versions.
The problem is with a machine in the production environment and we are totally blocked. We cannot export/import modules.
I have copied the admin tool and set up again, connecting to the same Oracle database, but I get the same error.
I will try to restore another oracle backup.
This is the ticket opened by a colleague PTC Case C17007472
Thanks for your answer
I have requested that someone reach out to you in the coming days - timing is subject to the ticket queue.
However, it is strongly recommended to upgrade once you are unblocked.
Kartik
I have received an email from support asking some questions, but when we answered we received the same message. "This version is out of support".
We solved the issue with an old Oracle backup, so I would like to know if it si posible to update Oracle database without updating Doors database, I suppose that it is impossible but I have to answer.
I have to update the Oracle database with all the import/export since the backup restored to sync with the doors database. If it is not possible to update only Oracle db, the Doors database will have duplicate entries that I have to delete and restore all links manually.
Any ideas?
