Java API im runreport: how to get results
DA_13428533
3-Newcomer
I want to use the java api to run a report and get the result.
It appears, from the documentation that running a report creates the output in the servers data/tmp directory.
From docs: "For security reasons, all file references on the PTC RV&S server are restricted to the data/tmp directory in the server installation directory."
Using the java api, is there any way to get the result of a report ?
thanks
Hi @DA_13428533
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina
PTC Community Moderator
PTC
