Version: Windchill 12.5
Description:
I would like to upgrade server version from 12.5 (with clients also on 12.5) to latest 13.3 server version and I am unable to find the minimum client versions which will work with server v13.3 after the upgrade is done.
What are the minimum client versions which will still work after upgrade?
Where can I see this documentation online?
Take a look here:
Your Post does not fit to the Question.
There had been the Question for the Minimum Client Release that is able to connect to RV&S Server Release 13.3.0.0
Following the Install- and Upgrade Guide, this shall be Client Release 13.0.0.5, or in other word: not the actual Client Release 12.5
Still left open is now the Question:
Your Hint regarding has to do nothing with the Question for Client-/Server-Compatibility,
Sorry
