Hello. I'm trying to install PTC Modeler 10.1 to my computer, with Standalone configuration, however could not manage it. Before I start, I want to inform that,
- I have 2 user account (Administrator and Local User) .
- I run installation module as Administrator,
- I disable my Antivirus software,
- I'm working in an offline environment, with my network card is enabled.
I intended to go with the clean Standalone installation with Local Modeler Server Instance (item 1), but I don't understand why it got so complicated, am I missing something? I'm trying to work under evaluation license and because of that issue I've wasted a lot of time, please help.
Take a look:
Hello VladimirN,
I looked the articles but those error types are not the same as I encountered (Those are related to SSL Handshake, in my case, SQL Instance seems not exist), nevertheless, I tried the suggestions as:
- I'm performing the installation with no connection to any network, with Administrator rights, to eliminate any policy rule restriction, but no effect.
- I controlled the registry values for TLS protocol (TLS 1.2) and ensured it is enabled for both Server and Client keys, however it does no effect.
hello,
One of our pre-sales engineers will be in touch to help.
thanks,
Patrick
