Hello All,
Installing and configuring PTC Integrity Lifecycle Manager. I'll prepare the database instance and database, as well as the port number, before starting the installation. During installation, the relevant tables will be created automatically based on the database connection details provided, or please advise on the database and table component.
Sasi
There should be an installation document available to you to that explains everything step by step. If you follow them, it's pretty easy.
