Hello together,
I want to export a document with pictures and excel files to a RIF export file and then import the RIF file into DOORS.
The problem is, that DOORS can not import png or xlsx files, only ole objects.
I import my RIF documents with Atego Exerpt.
How can I export my Text Attachments (png, xlsx, ... ) as ole objects?
Thanks!
Florian
Hi Florian Huber
there is a PTC Support Document (CS126310) which explains on how to import/export OLE attachements.
You need to use at least RIF version 2.1.1 and change the mapping in the gateway configuration file.
Dominik
Hi Florian Huber
Dominik
