I'm trying to create a query with a relationship. But it fails and have no idea why.
The command with error message:
im createquery --name=newQ --queryDefinition=((relationship["ID"] backwards forwards using ["Release"] = 3310308) and (field["Type"] = "Sprint"))
You may not supply operands (a selection) to: createquery
I have the same query defined in the GUI:
im viewquery SpecificSprint
Query Definition: ((relationship["ID"] backwards forwards using ["Release"] = 3310308) and (field["Type"] = "Sprint"))
Sorted By: ID (Descending)
Fields: ID,Type,Summary,State,Team,Sprint Scrum Master,Estimated Velocity,Sprint End Date,Sprint Start Date,Project
And that one is working on the command line:
im issues --query=SpecificSprint
3310312 Sprint Scheduled [XB1061A][R1024.0_V10] XB1061A Integration Sprint 0
So how can I specify that query on the command line 🤔
You must encase the Querydefinition in quotes, otherwise the commandline will not understand that this is a single argument and break it at every space.
Try:
im createquery --name=newQ --queryDefinition='((relationship["ID"] backwards forwards using ["Release"] = 3310308) and (field["Type"] = "Sprint"))'
Try:
Thanks! For some reason I could not see the issue 😅
