Is there any way in Requirements Connector to set the requirement Category type based on the Object type? Instead of a one to one relationship between requirement type to document container, DOORS NG uses multiple object types within a container. So a Header would be a Heading Object type, a Comment would be a Information Object type, etc. PTC Integrity achieves this with a Category field.
But once I refactor a multiple object type ReqIF file to something Integrity can read, I don't see a way to set the Category to reflect the above different Object types.
Anyone know of a way?
Hi pnewhook,
I don't believe this is possible, as IRC currently only supports the one object type, hence, why you need to refactor to begin with during import:
https://www.ptc.com/en/support/article/CS280996
You may want to open a Support case with the Integrity Requirements Connector support team, to confirm, and see if this has changed, as I haven't used IRC in awhile.
IRC has supported multiple object types since 3.1 (confirmed in the link you provided). I'm now using 3.4
