User Notification Problem
Software
I set up a user notification in Integrity to notify me when a defect or change request has been assigned to me.  It looks like this:
This works well except there seem to be a trigger that runs overnight that updates all of the Defects and Change Requests that are in the system.  When I look in my email every morning, there is a notification for every defect and change request that was ever assigned to me.
Is there something that I should change in my notification that would prevent this.  Also, I tried to exclude these items by using the user = -system- value but it did  not work.
Any help would be appreciated.
Happy New Year!
Ginny M.
3 REPLIES 3
Hi Ginny,
If you only want to be notified when you become the *new* assigned user of the item you can include another condition with the ones in your screenshot (one in each of the AND sections):
          Assigned User != - Me -
This condition, when used together with the Assigned User [new value] condition, will check the existing value to say "If I was not the previous owner before the edit but I am the new assigned user, then return true and notify me".
mrump
(To:Software)
Hi
another option would be to check wether the your field of interest actually changed, e.g.
Assigned User <> Assigned User [new value]
HTH
Matthias
Software
(To:mrump)
Thanks for the info Joe and Matthias.  I will give this a try.
