"Revision Description Required" for Revision 1.1
KaelLizak
"Revision Description Required" for Revision 1.1 (migrated thread) Posted: Apr 16, 2012 3:12 AM
becker Posts: 13 Registered: Nov, 2010
I'd like to have "revision description required" for Rev 1.1 instead of "initial version" automatically inserted in the revision description of 1.1. Is this possible?
Re: "Revision Description Required" for Revision 1.1 Posted: Apr 24, 2012 12:38 PM
Posted By: mlizak Posts: 72 / Registered: Feb, 2011
Hello Becker,
Unfortunately, this is definitely not possible. The default text for the initial revision description is compiled into the code.
Kael
Kind Regards,
Kael Lizak
Senior Technical Support Engineer
PTC Integrity Lifecycle Manager
1 REPLY 1
If this issue is of concern to you, please contact Integrity Support, so that you can be added to the appropriate SPR.
Kind Regards,
Kael Lizak
