Access mashup from another PC which is far away from Thingworx installed PC
AkshayKumar
Now i am successfully getting sensor data to My thingworx composer from anywhere using Cloud mqtt,, Now i want to Access the Mashup from Another PC which is far away,,Is it possible?? if so how?
My mashup url is http://192.168.100.12/Thingworx/Runtime/index.html#master=&mashup=Nodered_weather,,
can i access this using Something called VPN? is there any docs??
please Help me with this,
Thank you!!
KSM
(To:AkshayKumar)
Hi Akshay,
IT is possible to access from outside, as you mentioned the IP address in URL it seems to me that its a local IP, You need to use public IP, and also you need to turn off the firewall.
