Now i am successfully getting sensor data to My thingworx composer from anywhere using Cloud mqtt,, Now i want to Access the Mashup from Another PC which is far away,,Is it possible?? if so how?
My mashup url is http://192.168.100.12/Thingworx/Runtime/index.html#master=&mashup=Nodered_weather,,
can i access this using Something called VPN? is there any docs??
please Help me with this,
Thank you!!
Hi Akshay,
IT is possible to access from outside, as you mentioned the IP address in URL it seems to me that its a local IP, You need to use public IP, and also you need to turn off the firewall.
